Corrosion on alum boat
bubbakat
What is the best way to remove and repair a aluim.<br />boat that has corrosion on it. What to paint over it with and etc.
Winger Ed.
Re: Corrosion on alum boat
A wire brush on a angle grinder will get all the loose stuff off.<br /><br />Then wash it with 'Aluma-prep', its an acid sold at most automotive paint stores. Wipe it on with a Scotch-Brite pad.<br /><br />Rinse with water hose.<br /><br />Then there is another wash chemical for it called 'Alodine'. Wash it down using a Scotch-Brite pad using it.<br /><br />Rinse with water hose.<br /><br />When dry, prime with a good epoxy/Chromate primer.<br /><br />Paint.
