converting a jet back to prop
I have a 115 Yamaha. It now has a jet which makes it an 80hp. I'd like to be able to switch from jet to prop and back again when needed. I mostly fish rivers where the jet is needed. I'd like to use the boat on lakes but the weeds jam the jet. I know there are conversion kits available. Are these conversion easily done? I hear it takes a few hours to complete. The only issue I see would be the linkage for shifting. Any thoughts or recommendations? Thanks.
Faztbullet
If it originally came as jet you will need to install shift rod and linkage. Easier to swap a prop to jet than vise versa
