Re: Compression on 1986 johnson 8 hp?
Expect both to compress around 100psi and within 10% of each other.
Guages, technique and conditions vary so much that makers won't set specs on compression.
With a recoil start motor I usually accept anything over about 60psi, as long as both cylinders are within that magic 10%.
