chrysler 75 hp wont fire
jamiebrant
hey guys bought a swiftcraft stingray with a 75 hp chrysler wont start the starter solenoid is cactus but running a direct power it will still not start i used a multimeter and have got 12 volts going to the solenoid but on the distribution block everything says that its only got .06 volts and because im very new to outboards it is my first boat im unsure.theres power at the dizzy and at the voltage reg only .06 thats as far as i have checked i pulled a plug out and tested no spark i pumped fuel untill it went hard and started to drip out the bottom carby still nothing. does anyone have any ideas for me??
cheers jamie
Nordin
Re: chrysler 75 hp wont fire
There is a circuitbreaker connected to the prim.side of the solenoid. Maybe it is relesed. Maybe you have a resetbutton on it (newer type). The ign.system need 12volt to operate, that is why you do not have any spark at the plugs.
jamiebrant
thankyou for that info im pretty sure its a 79 model not to sure but the reset button is out i pushed it a couple of times and still no different could it be the ignition barrel?because i put a new battery and the boat has been rewired up to the engine but they left the original barrel in it i also checked the volts in the barrel it says it has got 12 running to it chen as soon as i turn the key on it dies to .06?? what does this mean???
cheers jamie
Nordin
Check if you have 12volt at the ign.system after you reset the circuitbreaker.
1979 do not know if it is magnapower ign. with distributer or Prestolite ign.
If you have distributer you should have 12volt at the blue wire going to the powerpack.
Nordin
Read your post again and you say you have 12volts at the powerpack with the key in off position and it drop to 0volts when turning the key to run position.
Sounds you have some wrong connections at the key.
There should be 0volts in off pos. then 12volts in run pos. and still 12volts in start pos.
You can check if there is some problem in the powerpack by disconnect the blue wire at the junctionterminal.
If you have 12volts at the terminal in run and start pos. at it drops when you connect the bluewire, you have a shortcut or groundingproblem in the pack.
jamiebrant
sorry my miswording i was having a play around with it last night and at the key if i test the + (red ) theres 12 volt turn the key on and it dies to.06. the motor has the magna ignition with the dizzy and with the key on it says .06 volts at the key too for everything and i follow it to the engine and the only think that has 12 volt is where the battery goes to the solenoid. the choke the generator,tacho,all says .06?? as i said this is my first boat and im pretty fresh to outboards the boat has been rewired all except from the barrel to the engine. sorry if im making it hard to understand
cheers jamie
Nordin
Seems you have wrong wirering. If you have chrysler/Force keyswitch and factory harness it should be like this.
Wire Connection at key
Red B
Blue I
Yellow S
Green C
The two left (M) are for magneto or CD ign with no battery feed.
At the terminal on engine the should be a decal at the exhaust side with information about colours and connection.
jamiebrant
hey cheers for that help mate nailed it down to a corrosion in the wiring run a new engine loom and she is sweet as purrs like a kitten did a compression test 150 psi in all cylinders. Thanks again for that .
