CaptainTDawg
Thread starter- Joined
- Apr 22, 2013
- 12
So, i am stuck in limbo on what to do. Yesturday, i unsiezed the vent plug on the lower gear case to check the Gear Oil. Right as i backed out the screw, the olive green oil started pouring out. I quickly plugged it back up. The oil looked in good condition, no water or metal particles in it. But im not sure if i need to change it. Last year, i used my boat about 3 times during the season, for a total of about 10 hours of runtime. in my manual, it says that the gear oil needs changing every 100hours of use or 6 months (I.e every season). So my question is does the gear oil go bad after 6 months? Is that why u need to change it every season? Or can i just use my existing gear oil since it has so little hours from last year? Thanks in advance - C. TD
