winterblues
- May 31, 2010
- 28
Re: changing color of boat (winter project) best way to do it?
YD- I thank you for your lenghty post on how to gel coat. However, i do not have a garage unfortunately. My boat is shrinkwrapped at the moment outside. I shouldve corrected myself and said early spring project. Anyhow i expect if i do use a gun I might aswell shoot it in a garage, so my spray method is out the door.
Wood- Again, I thank you too for your insight. I will end up going with your method with the sand, prime and paint method. It's cheaper and with the situation I am in, I have no choice onto do it this way. Unless I do all the prep work and send it to the paint shop (but of course $$$ is always the issue when someone else does it).
