cedar strip scarf joints
zenman
hey there
I am restoring a cedar strip boat...I need to replace some sections of the hull planking...several 12" to 24" sections...I will probably make the joins scarf joints...and now my question...does anyone have a jig design to attach to the hull to scarf the joints on the hull?
Thanks
Gerry
DuckHunterJon
Re: cedar strip scarf joints
You can build a jig to clamp to the board (or side of the boat) that consists of a shallow ramp (equal to the angle you want the scarf). The ramp has an open area in the center wider than the board you are scarfing. Now build a large enough sub base for your router to span the sides of the ramp. You can use a straight cutter bit in the router to rout the scarf. I made one for a one time joint (forgot to cut it before attaching it to the boat). If none of this makes sense, let me know and I'll try drawing something up.
zenman
Thanks for your reply...how did you attach your jig to the boat?
