anauburnfan
- Aug 23, 2010
- 24
Re: CDI test procedure question for 1988 johnson 200
Before I write anything else, I must say how much I appreciate all the help and suggestions from you folks. It really reduces the frustration of trying to figure this out.
As for the last 2 replies
Yes I can take a picture tonite showing the pack. I will take one with the pack in place and one with it pulled back so the wiring is visible.
As for the cdi testing I will go ahead and run through those tests. When I checked the dva for the orange coil wires this weekend it was with engine idlibg on the hose. I have not gone through the link and sync procedure yet - just got the service manual at christmas. Someone had suggested previously that I do that, but had to wait for manual. Looks like it is pretty straightforward procedure, and the only reason I haven't done it yet was that I got a little discourged after reading about the tdc setting and needing a piston stop tool to verify that and the test wheel requirement for the timing adjustments...at this point all I can say about timing is that tdc seems like it is close to where the mark is going by a feeler wire stuck in the plug hole while rotating flywheel by hand. And timing at idle on hose reads about 10 degrees atdc which I know is not how it is supposed to be tested.
As for the plugs, they are champion and they were new when I got motor, though it has never run right in water since I got it. Since then (around august) I have only run it in water for brief peroids of time to test it. Maybe 4 hour total maybe I should just go ahead and replace them to be sure. It will take me a while to run through the tests and linkage, but will report back when those are done. I will post the pics tonight though.
Thanks again for all the assistance.
