caulk
CJSCARTERCRAFT
What Type Of Box Store(lowes) Caulk Could I Use On A Plywood Boat, To Reseal The Factory Caulk Inside The Haul.
zach103
Re: caulk
you can probably just find some kind of silicone caulking that can be used for exterior applications
cr2k
Re: caulk
Be aware that there are 2 classes of marine caulk. One for sealing etc. ABOVE the water and one for Below the water. If you get below the water you can use it either. Life seal is one of the best quality brands, but not cheap.
