Carver 2357 Montego rebuild
redneck joe
Re: Carver 2357 Montego
tabs show out for delivery so probably pull out tomorrow and work on that.
going to fill up and take gps with me today. Hole shot is awesome once the tabs get put on will be more awesomer
Replaced ignition switch which promptly fell apart. Pissed off but a pair of pliers got me running. Then I dropped my $300 GPS in the lake
all new rollers on the trailer. Never did that before. Wouldn't think it would have nee that hard.
going to start lookin at the instructions for the tabs. Never drilled thru a boat before....
and so it begins
redneck joe
Tabs on back in water. Not sinking
redneck joe
put steps on the trailer
redneck joe
so the capacity on a trailer winch, thats pull pounds, not boat weight right?
and could i wire into the electric brake plug ro all the way to the battery?
Electric Winch 2 000 Lb | eBay
redneck joe
Separate line to the battery and install a breaker near there.
I did this last year or so, kind of a PITA in the procurement of parts not so much the labor. If you go to the heavier wire (#2 IIRC) you can't find matching terminals ring terminals and the standard 2 plug winch plug does not take that size wire anyway, so kind of pointless IMO. Ended up with #4 (or was it #6) I think so that the crimp terminals, ring terminals and the winch plug would all match up.
The breaker I installed near the battery works as an on/off switch too to shut the circuit down when not in use.
If your gonna do it let me know and I'll shoot ya some pics of how I did the RAM.
Need a set of these, and the wiring to match.
Powerwinch Male/Female Socket F/12V Winc PWR-P77022AJ, Winches & Windlasses, JMSOnline.net Marine Supply and Boating Store
A general guide is for the winch rating to be no less than 75% of the total boat weight, including equipment. The breaking strength of the strap, rope, or cable should be at least 1 ? times the winch rating. Breaking strength of the hook should be 1 ? times the breaking strength of the strap or rope and 1 ? times the breaking strength of the cable.
redneck joe
notice anything wrong?
redneck joe
yeah dumb### you wired up without the gasket on
redneck joe
bunk glides on and works
worth every penny. Barely had the trailer wheels in, rather than back truck wheels touching. Straight on, centered, easy cheesy. Only thing i didn't like was wading out that far; going to have some steps welded on to can walk the trailer out.
redneck joe
btw the dock ramp is usually about 4-8 feet out of the water. Right now its about 3-4 feet under water.
redneck joe
Time to replace the hatch. The old:
redneck joe
took a weekend off and hauled down to the big boat
me and mrs on Lake Guntersville
redneck joe
played a bit with the 'free' bimini. Ordered $130 worth of parts to marry the two together. I'm going to eliminate the straps yet still foldable for trailering
took a break on Tim's Ford
redneck joe
ok here was yesterday.
who knows how old porta potti. rotting out and/or mice eating the plastic what you cant see here is where the had apparently tried to repair the pump with duct tape...
redneck joe
you can kinda see the tape also, note the push button. That was wired to the macerator right behind the head in the closet that pumped directly from the portapotti overboard.
