carb rebuild on 88 special
bquick8
rebuilding the carbs on my 1991,88 special.Everything is really clean,no gunk or varnish.When spraying carb cleaner through the passages under the "freeze plugs" found one that's obstructed.What's the easiest way to remove and reinstall these plugs?
Xcusme
Re: carb rebuild on 88 special
Some folks use either a sharp awl or sharp finish nail to punch through the disc and pry it out. Don't go in too far, you don't want to 'bottom out' the awl or nail. Install new disc with dome side out and using a flat drift, flatten disc until it's just flat.
tashasdaddy
i use a short ice pick. the use a short piece of 1/4 in. wood dowel , with a tack hammer to install the new ones.
