A few weeks ago I bought a new carb to replace the POS that had been acting up. Boat is a 1977 tiara w/ mercruiser 898 (chevy 305) and alpha 1 outdrive. It turns out the original is a rochester 2 barrel and I bought a mercarb instead because i'm an idiot. I obviously thought I ordered the right one, but I did not. It looks exactly same and the boat runs but I've been having some problems recently but I'm not sure if this the cause as many other parts have been replaced and fixed.
This is the carb that I received in the picture. It has the vacuum tube. The Rochestor did not. It came with a small rubber cap on it, but I think this is what's causing the problem.
The problem is rough idle and then sometimes it backfires once warm, especially with a heavy load going into waves. The only thing I can think of is this vaccuum tube or a bad gasket that is causing an air leak. I've taken it into a reputable marina/mechanic and they fixed the exhaust bellows, they said the last place used the wrong adhesive. Can I just plug this vaccuum tube or do I need to go back to the rochestor?
