1993 Johnson 150 V6 60*
James R
About to reassemble after boring. My machine shop pointed out that the tiny check valves associated with the crankcase drains need replacing, 6 of them.
He told me that they come out by hooking them and pulling.
I looked at BRP drawings but I dont see them listed. Can you help me please.
Dhadley
Re: 1993 Johnson 150 V6 60*
Were they refering to the ones on the outside of the block?
James R
These are situated in the flange of the crankcase on which the reed assemblies fit followed by the carbs of course.
James R
Many, many thanks to you DHadley. I will run this by my dealer and see what can be done.
I appreciate your prompt help.
James R
Went to my dealer and got his engine man to check. I think he had to look at a later model to find the drawing with the elbow check valve assy.
The number we came up with is 437784.
He told me to knock the old ones out with a punch. Might I run the risk of cracking the casting or do they come out easily.
Can you confirm all this please.
Thanks again.
Dhadley
That's another 90* fitting, probably a different hose size. Since he's looking at your block I'd let him order them and if they aren't right he can send them back.
