I have a Class 1 hitch with a 2" drop from the receiver height. The trailer I have is about 4" higher than the ball when level, so can I simply invert the hitch to and put the ball on the top to get a 2" rise instead and use it this way to tow?
Thanks guys... flipped it over, and worked just fine!
just to be clear how much weight are we talking?
my cuddy is 6240 lbs on trailer and i needed a 7 inch raise. i bought a cheap $20 hitch and flipped it for a 6 inch raise 10 miles down the road the dam thing cracked in 2. so i went with a 7 inch raise, solid, class IV, 12,000lbs hitch and a 12,k ball i don't have any problems. weight wise when you flip the hitch over to make it a raise you actually double the amount of stress on everything..
my cuddy is 6240 lbs on trailer and i needed a 7 inch raise. i bought a cheap $20 hitch and fliped it for a 6 inch raise 10 miles down the road the dam thing cracked in 2. so i went with a 7 inch raise, solid, class IV, 12,000lbs hitch and a 12,k ball i dont have any problems. wieght wise when you flip the hitch over to make it a raise you accually double the amount of stress on everything.
now if your boat only wieghs 2,000lbs then i dont THINK there will be a problem, but just double cheak.
and no my truck doesn't sit that low the trailer sits that high.
Gun Dog - think about the change in tounge height if we were to take the hitch in the image, and rotate it 180degrees.
