I would like to build a swim platform for my 26' Larson Cabrio made from fiberglass. I toyed with the idea of a teak platform but I really feel that it will not go with the boat and upkeep will always be there. The platform will be 8' x 2.5'
So my plan is to:
-Sandwich a 1.5" foam core with 1/2" plywood to give an overall thickness of 2" +/-
-Use 4 struts to support the platform underneath.
-At the strut support locations eliminate the foam and use wood.
-Cover the platform with fiberglass cloth (type/weight/# of layers?)
-Sand/Fair/Prime/Paint
-Use Durabak to create a non-skid top section
Is my proposal a valid one? Any concerns with this type of construction?
I have never used foam as a media before- and I planned on using the "tuff-board" found at most home improvement stores (not the pink stuff).
I really appreciate any input on this, thank you.
So my plan is to:
