Bow light wiring dropped into the hull...
We took bow light out for replacement, didn't get around to installing the new one for a few days and the wires dropped into what looks to be an irretrievable area behind the built in cooler (1999 Stingray 190RS Bowrider). Does anyone make a battery powered bow light that will take the place (and spot) of the original screw mounted light? Am I screwed and have to find a way to run new wires? TIA!
Silvertip
Can you see the wire with a pen light? If you can still see the wire, make a hook on the end of a piece of stiff wire and fish it back out.
GA_Boater
Some inside out duct tape wrapped around Silvertip's hook may also assist snagging the wire even if you can't see it. It's down there waiting for you.
fishrdan
^^^ That's what I was thinking too.
If you can't see it, duct tape a piece of 3/8 or 1/2" hose to a shop vac, then probe around to vac the wire out.
They do make battery operated bow lights, they run a couple of D cell batteries. I would opt for the proper repair though.....
