TripleJGraffis
- Jan 18, 2024
- 305
LOL. Depends on if we have another mild winter this year or not.Since it's an outboard you will enjoy time out on the water when you get done this winter....
Maybe because you can take an outboard inside to work on???And what do you mean by "since it's an outboard"? Do outboard fare better in the cold than inboards?
Outboard motors are designed to drain the raw water when they shut off as long as the tilt is adjusted to have them completely vertical.LOL. Depends on if we have another mild winter this year or not.
Yeah, I am slowly accepting this fact. It's kind of a downer that I most likely won't get it out this season.....But definitely in winter if the temps are as phenomenal as it was back in February here in Wisconsin!Nah..... Ole Coots just saying you won't geterin da wadder this season.
Peeps dues dat herea.
You know... The more I hear about them....the more I feel like inboards are more of a pain in the ass that outboards! LOLOutboard motors are designed to drain the raw water when they shut off as long as the tilt is adjusted to have them completely vertical.
That's why you don't see an army of people rushing to get their outboards winterized before the first freeze happens unlike inboard equipped boats.
If you plan on taking a raw water only cooled inboard boat during wintertime where the temperature possibly will get below 32 degrees F, you have to drain the cooling system completely when it is not being used before the cooling water freezes.
Heat exchanger equipped inboard engines only need to drain the raw water portion of the boat but the closed cooling portion that has the toxic antifreeze water mix like in automobiles can stay remaining if the mixture is done properly to work at the lowest freeze point needed for the location.
Yup!! I will only have an outboard, so I can pull it off & bring inside my heated garage during the our Canadian wintersYou know... The more I hear about them....the more I feel like inboards are more of a pain in the ass that outboards! LOL
So I don't have a heated garage. How do I handle my outboard? Souds like I can tilt it into a fully vertical position and all the water will drain out and not freeze....Therefore, leaving nothing else to do with it....but others recommend to winterize by draining the lower unit lube and adding antifreeze.....What's the best method to keep it in the best possible shape in my situation?Yup!! I will only have an outboard, so I can pull it off & bring inside my heated garage during the our Canadian winters
check gear lube BEFORE winter? Souds like I can tilt it into a fully vertical position and all the water will drain out and not freeze....Therefore, leaving nothing else to do with it...
Since you are in Wisconsin you don't have to worry about a "fresh water flush." If you are using the boat over the winter, when you come off the water make sure the outboard is vertical to let it drain. Before it gets cold, unscrew the bottom gear case screw and insert the gear case lube nipple of your gear case tube. Remove the top screw and squeeze in lube until lube comes out the top. If it is nicely colored lube, replace screws. If it is milky/watery, drain and replace lube.So I don't have a heated garage. How do I handle my outboard? Souds like I can tilt it into a fully vertical position and all the water will drain out and not freeze....Therefore, leaving nothing else to do with it....but others recommend to winterize by draining the lower unit lube and adding antifreeze.....What's the best method to keep it in the best possible shape in my situation?
Sorry, I meant to bring inside to work on; not for winter storageSo I don't have a heated garage. How do I handle my outboard? Souds like I can tilt it into a fully vertical position and all the water will drain out and not freeze....Therefore, leaving nothing else to do with it....but others recommend to winterize by draining the lower unit lube and adding antifreeze.....What's the best method to keep it in the best possible shape in my situation?
Well, yesterday, I recorded 96 degrees inside the tent.MEKP...... No
Resin..... depends on how warm it gets
