Boat won’t shut off
alldodge
Should there be power present with it unhooked and motor off? 12.6v?
On one of the wires yes, but I was asking if there is power at the coil or key purple wire. One of the 2 wires on the ALT other then the orange wire comes from the 50 amp breaker. The breaker has Bat voltage full time
Albaj13
Hey does this need to be switched? I forgot to take pics before I took it off
Albaj13
This is how I have the circuit breaker wired right now. Not sure if the wires need to be reversed
alldodge
No issue with wiring
The reason for disconnecting the ALT wires was to see if there was a problem with the ALT which was back feeding the ignition. Doesn't appear that is happening
Albaj13
Hey I had the wires reversed on the circuit breaker and the assist solenoid. It’s running and shutting off. Thank you
alldodge
No way swapping those 2 wires would fix a no shut off issue, there was something else
Albaj13
all I did was move that orange wire to the other side of the fuse panel and swapped the wires on the assisted solenoid and reversed the circuit breaker wires. Shuts off now
alldodge
ok, more then just swap 2 wires
A breaker is like a switch, can connect either wire on any side. Swapping wires is nothing and has no effect on anything. Moving other things you mentioned is probably what fixed the issue
Albaj13
I also moved the purple wire to the ignition. Thanks for the help man! Much appreciated. Finally get to enjoy this thing
  • IMG_0642.MOV
Albaj13
Another issue. Apparently when I unhook purple wire to alternator it starts/runs/shuts off normal. However, with purple wire plugged in and all plugs in alternator it does not shut off.
Albaj13
Where does the red/blue wire from fuse block go to on my switch ?
Albaj13
I have red/blue together w purple on ignition part of switch . Boat runs greats . Lanyard works. Shuts off fine but only with this purple wire on alternator unhooked
alldodge
The Alt is back feeding the ignition. Need ALT repaired or replaced
Albaj13
Is it okay/safe to run with just that purple unplugged at alternator? Seems to be running fine otherwise
