boat paint prep
KC4ZQZ
Re: boat paint prep
FWIW: I see you've been sanding down as fine as 250 grit. I think the surface prep instructions for the Pettit 2-part epoxy primer only calls for 60 grit surface prep. I realize that none of this is written in stone but I'd hate to see you sand down "fine" only to have to rough it up again for the primer. Others on the site are much more informed on these isues than I.
maagee79
Re: boat paint prep
Thanks for that input I've been busyand haven't been able to work on it the past few days. Do you know where I can get the prep instructions for that primer? I haven't ordered it yet but will be doing some prep work on it this weekend.
Woodonglass
Re: boat paint prep
Pettit Protect High Build Primer Specs
DRY TIME at Substrate Temperature
To Recoat
To Paint
To Launch
90 Degrees F
2-16 hours
3-6 hours
48 hours
70 Degrees F
3-18 hours
5-8 hours
72 hours
50 Degrees F
6-24 hours
7-10 hours
120 hours
    • PHYSICAL DATA
VEHICLE TYPE.....Epoxy/Polyamide
FINISH.....Low Luster
COLOR.....Light Gray
COMPONENTS....2
MIX RATIO (A/B)...3 to 1 (by volume)
CURING MECHANISM....Chemical Cure
SOLIDS (theoretical)
By weight.....71 +or- 2 percent
By volume....56 +or- 2 percent COVERAGE.....225 sq. ft/gal.
VOC....378 g/l max. (admixed)
FLASH POINT....80 degrees F APPLICATION DATA
METHOD.....Brush, Roller, Airless or Conventional Spray
INDUCTION PERIOD....15 minutes at 70 degrees F
NUMBER OF COATS....3 min.
DRY FILM THICKNESS PER COAT.....4 mils (7.1 wet mils)
APPLICATION TEMP (air & substrate).....50 degrees F. Minimum, 90 degrees F. Maximum POT LIFE.... 2.5 hrs. at 90 degrees F
5 hrs. at 70 degrees F
10 hrs. at 50 degrees F
    • APPLICATION INFORMATION
Stir both components thoroughly. Mix the two components together in the ratio of 3 parts of Component A to 1 part of Component B by volume. Allow to stand 15 minutes at approximately 70 degrees before using. (Allow to stand at least 30 minutes if temperature is between 50 degrees and 65 degrees F.) Primer may be applied by brush, roller, conventional or airless spray. Thinning is not normally required for brush or roller application, however, small amounts of 97 Epoxy Thinner may be used if necessary to facilitate application. For spraying, use 97 Epoxy Thinner at levels of 5-10 percent by volume to ensure a smooth finish with minimal orange peel. Wet film thickness should be 7.1 mils per coat, which yields 4 mils dry film thickness. A wet film thickness gauge should be used to monitor paint application. Total dry film thickness for a three coat application should be 12 mils minimum for maximum coating performance. If this has not been achieved with three coats, additional coats are recommended until 12 dry mils is reached.
    • SURFACE PREPARATION
Coating performance, in general, is proportional to the degree of surface preparation. Follow recommendations carefully, avoiding shortcuts. Inadequate preparation of surfaces will virtually assure inadequate coating performance.
Bare Fiberglass: All fiberglass surfaces, regardless of age, should be washed at least twice with Pettit 95 Fiberglass Dewaxer. Change rags frequently to ensure complete removal of wax, mold release, or other contaminants. Sand the surface thoroughly with 60 grit sandpaper and rewash with 95 Fiberglass Dewaxer to remove sanding residue. Apply at least three coats of Pettit Protect High Build Epoxy Primer 4700/4701 following the application and recoat instructions. Finish with two coats of Pettit antifouling paint.
Blistered Fiberglass: Refer to Pettit Technical Bulletin TB1000 Gelcoat Blister Repair and Prevention Specification for detailed instructions.
Bare Steel: Sandblast to SSPC-SP 6 Commerical blast, blow off residue with clean, compressed air, and immediately apply three coats 4700/4701 following application and recoat instructions.
Alternatively, hand sand with 80 grit sandpaper or power hand tool clean, then remove residue with clean compressed air or by vacuuming. Immediately apply one coat of Pettit 6980 Rustlok Steel Primer and let dry to a tack free state (usually 30 minutes to 2 hours, dependent on temperature). Then apply three coats of Pettit Protect High Build Epoxy Primer 4700/4701 following application and recoat instructions. Do not let Rustlok Primer dry longer than 2 hours under any circumstances before applying Pettit Protect High Build Epoxy Primer 4700/4701.
Bare Aluminum: Sandblast (using non-metallic media) or disc sand the aluminum to clean, bright metal. Wipe clean of residue and immediately apply one thin coat of Pettit 6455/044 Metal Primer. Let dry 8 hours minimum, 48 hours maximum, and apply three coats Pettit Protect High Build Epoxy Primer 4700/4701 following application and recoat instructions.
Keels - Lead: Disc sand or otherwise abrade surface to bright metal; clean off residue. Apply one thin coat of 6455/044 Metal Primer and allow to dry eight hours. Apply one coat of Pettit Protect High Build Epoxy Primer 4700/4701. Let dry to recoat. Then, if fairing is required, apply Pettit Protect 7000/7001 Epoxy Fairing Compound. Sand smooth with 80 grit sandpaper and follow with two additional coats of 4700/4701 per label directions.
Keels - Steel or Cast Iron: Disc sand or otherwise abrade surface to bright metal and clean off residue. Apply one coat of 6980 Rustlok Steel Primer, allowing to dry only 1/2 - 2 hours prior to overcoating, no more, no less! Apply one coat of Pettit Protect High Build Epoxy Primer 4700/4701. Let dry to recoat. Then, if fairing is required, apply Pettit Protect 7000/7001 Epoxy Fairing Compound. Sand smooth and follow with two additional coats of 4700/4701 per label directions.
Previously Primed Surfaces: Pettit Protect High Build Epoxy Primer 4700/4701 may be applied over existing two part epoxy finishes, provided they are in sound condition. Brush-off sandblasting or very heavy sanding with 60 grit sandpaper is required to maintain maximum adhesion. Then apply three coats of 4700/4701 per instructions. Remember, coating performance is only as good as the surface to which it's applied. All existing two package epoxy finishes in poor condition, as well as one package primers and bottom paints, should be removed completely and the appropriate bare system as described above should be followed before using Pettit Protect High Build Epoxy Primer 4700/4701. Total dry film thickness is more important than the actual number of coats applied. On metal and fiberglass, if 12 mils total DFT is not achieved with three coats, additional coats are recommended until 12 mils total DFT is achieved.
  • Reduces water absorption in fiberglass hulls and prevents osmotic blistering.
  • High film build for maximum protection with fewer coats.
  • Excellent water and chemical resistance.
  • Exceptional protection for steel, aluminum, and other metals.
  • High Performance System for Underwater Running Gear.
Below Water Line (yes/no):
Yes
BRAND:
Pettit Z-Spar
Number Of Parts:
Two Part
Type:
Barrier Coat Primer
Material:
Epoxy
molo_30
Re: boat paint prep
Is that weeds growing out of the boat? Like a floating horticulture machine! Looks like you have some fun ahead of you, good luck.
KC4ZQZ
Re: boat paint prep
maagee, how's it going with the boat work? I'm having to sand a lot of the gelcoat off in places to get rid of the majority of the cracks. I'm wondering just how much of those little cracks the 2 part epoxy primer will fill cause sanding is getting old really fast. How far along are you on the paint prep?
maagee79
Re: boat paint prep
I just got the boat flipped over this past weekend so I haven't gotten much done. I plan on sanding this weekend. The two part primer only calls for a 60 get sand so I just plan on getting it all sanded that way.
