boat building materials.....
oops!
there is a lot of questions here on what kind of materials do i use for this???
pt or marine ply???
stainless screws or drywall screws.....
so...im gonna make a list......
i been thinking about it for a while.....
a list of types of wood....
types of cloth
resin.....and so on
then, using manufactures info on the product...present it, in a easy iboats list.
please add your suggestions on an item you would like to see
cheers
oops
fuzzeywiggler
Re: boat building materials.....
Alright this will be great glad ur doin this!
Fuzzey
kennyboater
this is a great idea.
it will help me and some other of the new people out
tashasdaddy
get ready for the controversy. as you no i am not an advocate of pressure treated wood. there is something about stainless needing to be in an oxygen environment.
oops!
yeah...i hear ya buddie..!!
im not going to write it in any way shape or form like an opinion post...
simple facts from the manufacturers describing the product...
just gonna say what marine ply is and why they call it that....
what csm is and the different types...and when the manufactures suggest it to be used.....
its gonna take a while ...mabe 6 months worth...and ill submit it to you and the mods before it goes up....so all is cool with the rules.
cheers
oops
jcsercsa
Hay Buddie , are you going to include foam in that ??? lol
That does sound like a great idea , If you need some help let me know ...John
oops!
yup ...foam....
all the most common types used.......including pool noodles and ping pong balls.....:D :D :D
from kevlar to composite.....just the facts....let the builder decide..!!!
and yup ill need your help...!!!:D
especilly with the boat building progress under different amounts of beer. !
say one beer...good progress...10 beer great progress....(till we see it the next day) :eek:
JustJason
hmmm
Mahogony... Fir... for construction
cypress... teak... for trim
Pressure treated..... hmmmmm
I have used it... and will use it
However.... Mohogony is my choice... it's always been cost/availability thats been the compromise.
Searay and others use foam for their stringers.
Glass... be it epoxy or poly or vinyl... will not bond to PT. You can get it to stick if you rough up the wood with 36 grit... but it will not bond.
But... even in the bilge area... unglassed PT will last a long long time. Keep in mind that PT come's a million different ways... and the stuff you buy at depot is not the same PT that you can get from a true lumber yard that is treated for marine use.
Stainless.... hmmmm.
For trim its fine
For construction.... boat hulls flex under use. Having very little iron stainless isn't very tensile. The heads can pop off under stress... takes less than you think.
I'm a big fan of brass. Very malleable... it will stretch, and not snap. There's a little care when using brass. You can't just grab the screwgun (aka dewalt 18V) and start hammering them down. They will strip out. You need to use oversize, extra coarse screws... predrill, and cut reliefs for the heads for it to perform well.
For glass... Epoxy and poly work equally as well for the homebuilder. And you don't really need epoxy unless your constructing something hi performance and the weight/strength ratio is a major consideration. Personally i'd stay away from vinylester as a homebuilder... its a PITA to work with.
I'd like to hear more about the newer synthetics/plastics that people are using in for home construction. Stuff like trex and vinyl trim. I'd be curious if anybody as any experience with those type of materials.
`tip of the hat to ya~
jcsercsa
yup ...foam....
Yes Sir I am Up For that , I can start today !!!!! and how about I start with the ten count day ???? waiting your orders !!!!!!!!!!! lol I can tell the wife we are doing research !!! John
Coors
CDX, or Fir; pt takes to long to dry, and new stuff is hell on fasteners.
Composite decking 5/4- no lateral strength, but when wrapped with biax, can't break it.
Dried Glu-lam beams, like the ones used across the 16' garage door on a wood framed house are great for engine mounts.
All of the above en-capsulated with epoxy and your choice of cloth/biax/roven.
lol
And even, if you have to install more bracing-lose the water-loving foam.
Any deck screws into stringers, over-drill and pour in epoxy, with milled. Epoxy and any cloth on all sides of decking.
Why do it twice?
Coors
We all might learn a little on this thread, so many opinions, but it boils down to-who has done it/ been through it, and did it work?
I vote all theories banned; only did it work allowed.
oops!
actually coors...i think a lotta ways will work......
ie...... to fix a hole in your boat.......duct tape and paint....:eek: :D
this list will be just a thing that says......
marine ply.....less or no voids between layers of the ply...avalable in vairing mosture contents.....
and a link to a marine plywood technical specs.
polyester resin.....most common fiberglass bonding material... ..weakest of all boat building resins.......used in most small pleasurecraft applications .....avalabile in varying stregnths.....
and then a link to technical specifications....
.....if i do it that way.....then there will be no room for opinion.....just the facts as presented by the manufacturers.....that way the boat builder to be can make up his own mind on what to use for his project...and his boat....
application procedures are as individual as the user...ie.......i use a wide blade putty knife to spread resin.......the other guy says......a roller is better....
i dont want to go there....let them spread the stuff with thier fingers if they want.....
my idea is just a list of the most commonly used products...and some technical information about them.....
whadda ya think?
Coors
Sounds good- still the poly/epoxy opinions will be here, pt/ cdx, etc; but good.
Kinda put it together in one place, and force people to read threads before asking questions that have been answered 200 times.
Yeah, right, lol.
Maybe the forum needs a new topic- RESIN
Dunno, newbies can't seem to get in correct forums. and my experience lately is; I log in , and while typing, have lost my log-on every 20 minutes; Tash? is it just me?
oops!
the epoxy - poly question will allways be there.....but both work for our little 16-24 foot lake put puts...
but i hope this will give them a chance to do their own research and decide for them selves...instead of starting another ..."epoxy vs poly question...whats better?" type thread.
i had that problem a while ago.....when you hit a new post or thread...hit refresh...
if that clears up the problem....and your still logged on.....
go into internet options and click "allways search for newest page"
my browser was going to old pages, before i logged on..and kept going back...it was pulling the page outta memory not the live stuff off the net
cheers
oops
JustJason
Kenny... this was written in a pm to you... but apparently my message was to long for a PM... and i was asked to shorten it.... instead i just posted my reply to your PM here.
Hey Kenny,
Welcome to Iboats.
Well.... you asked the 64 thousand dollar question with that one.
It's all about compromise.
How much do you want to spend... and how long do you want it to last? is the question.
There is a mountain of information out there and try not to read into any 1 thing to much. There is no universal answer to anything.
What ever wood you choose to use will work. It's just a question of for how long.
You can hollow out a pumpkin and it will float. You can hollow out a giant pumpkin and jump inside of it.... it will still float.
Alot of brand new boats out there advertise "no wood" as a selling feature. No wood means no rot right???
Well, wood, whatever species, has a lot of beneficial properties to boat construction. Way to many to list... and i'm sure i do not know them all anyways.
In most boats, its actually advantages to use wood here and there.
We've been doing wood for 2000+ years.... and glass for the last 60.
In your note... you said
kennyboater said:
if i do not have to spend the time and money glassing
Try and get that out of your head... boats cost money, even if your doing the work yourself and getting material at wholesale. Whatever figure you have in your head at this moment... double it if you want the boat to last for a few years.. triple it if you want it to last a long time.
If you do the boat in rough pine... but your a hell of a fiberglasser.... the wood will never be exposed and will last forever. If you use Mahogany, and are a half assed glasser... it will still last a long time because mahogany is a good base wood that resists water and rot naturally. If you use pine and can't glass to save your life... it will last maybe a year. If you use PT throughout... and you don't glass... maybe 3-5 years. If you use PT and glass the best you can maybe 5-7. Again it all depends on how dry your boat stays on the inside. Do you leave it out uncovered in the rain... or is it garaged all the time. is it on a salt water mooring, or a freshwater dock.
By design... PT wood (ply or rough stock) is made to resist penetration by everything... including water. For years people use oil based stains and varnishes because oil does not mix with water, it repels it.
It's all about how deep you can work oil into the wood.
Working oil into the wood takes time... and time is money. So the next best thing is how to seal it instead. Polymer varnishes and fiberglasses work best for this.
Even marine grade varnish... expect to apply at least 7 coats to the final product. and expect to sand and re-apply once every couple of years.
PT mechanically infuses the wood with oils and anti rot, anti fungus agents. What would take you 50 coats by hand... can be bought by buying PT wood.
If you look at pine as a wood. Its very poreus... but also very sappy. If you kiln dried it and got the sap out it's still very poreus. Its is going to suck up anything like a sponge.... be it water or varnish or glass. Pine dampens vibrations well but isn't a notably strong wood.
If you take mahogany.... its not as poreus and has no natural sap. It will not absorb water easily... but it will not absorb glass easily either. Glass will still stick and bond to mahogany if high quality glass is used by an experienced glasser. (needs to be thinned). Mahogany has good strength and vibration properties.
PT.... well... it resists glass. and it resists water... and about any other thing you can pour on it... but... it only resists it for so long. then the wood will give and start to rot. You can glass over it.. but it's more like a band aide on an open wound... instead of stiches. Glass will stick to PT if the wood is roughed up like crazy. But glass will not bond to PT, it will not penetrate PT enough to become one with it. Even with a great glass job, because boats flex under use, the glass will eventually start to peel away off of the wood.
If you are gonna ask me what i'd do... don't. Because what i do is a decision based on compromise between me an my customer.
But.... if money were no object... and i glass like a madman... i'd do mahogany and epoxy resin all the way.
Hope this helps!!
Cheers!
Jason
oops!
well thats a few hundred hours off the total....:)
thanks jason..........
really good pm
wca_tim
has anyone lacated the best place to purchase ping pong balls in bulk yet?
oops!
i got an e-mail into adam and jamie......i hear they have some for sale !:D
jcsercsa
I vote all theories banned; only did it work allowed.[/QUOTE]
Yea but how are you going to do that ??? i think it just all the component's of any of boat building , what there strengths and weakness's !!! john
kennyboater
Hey Kenny,
Welcome to Iboats.
If you take mahogany.... its not as poreus and has no natural sap. It will not absorb water easily... but will not absorb glass either. Glass will still stick and bond to mahogany if high quality glass is used by an experienced glasser. (needs to be thinned). Mahogany has good strength and vibration properties.
Hope this helps!!
Cheers!
Jason
thanks so much jason; very helpful.
i sent you a reply in PM so i dont get this thread offtrack.
again; thanks
