Blue Fin Spectrum complete restoration
  • Gluvit
    Votes: 0 0.0%
  • Something else
    Votes: 3 100.0%
  • Total voters
xmxaxrxtxyx
WELL I DRILLED A HOLE THROUGH MY HULL!!!! Progress is slow cause of all the small stuff I hafta do before I lay down carpet:( my dad is helping me now so it's going much faster!!:)
ADVICE: Don't go back and forth to your boat while your restoring it!! Find a volunteer!!
chasmo
Lol great point!! Where would I go to get this aluminum?
​You would be surprised what you can do with old aluminum extension ladders I an aluminum boat with no sub floor. Used them on my SeaNymph 14R flooring.
xmxaxrxtxyx
Now THAT is a good idea!!!
xmxaxrxtxyx
NEED HELP HERE GUYS!!!
My dad did most of the wiring in the boat & he connected all the ground wires to the hull.
I didnt really like that, but he's my dad and I figured he's smarter than me anyway!!:/
Now after some searching I find you DO NOT want to ground to the boat!!
Can anyone confirm this, and if so tell me why not?
xmxaxrxtxyx
PS: all the ground wires are connected to the hull with a rivet "if that makes a difference?
jbcurt00
Nope, on an alumimum boat you DONT want to ise the hull as a ground.
TruckDrivingFool
It's common in automotive wiring to use the chassis as a ground but when you do it in a tin boat you turn the hull into a big anode. While it might take years we don't need to invite an more corrosion then we have to.
Edited to add: You can run all the grounds to one binding post for convenience just make sure it is isolated from the hull.
xmxaxrxtxyx
Well could I have 1 ground wire running around the boat and have everything connected to it, or should they all be seperate?
Bow Guy
I am interested in how to mount the single ground post/bar also... following!
Nice work xmxaxrxtxyx !!
TruckDrivingFool
Now that I'm not fresh off of work and I've had some sleep lets back up a step Marty,
A chassis ground like this
You don't want for the above described reasons. If you're talking about merely riveting a wire/cable support to the hull then you're ok so long as you seal the hole.
On a small tiller boat with just say a fish finder on one side and a few lights it may make more sense to just home run (a + and - the entire length) everything to a control panel or the battery.
Give us an idea of what/where you are powering and we can help with a plan.
I haven't looked in your thread (today) but post up what you're trying to do and you know we can give you ideas.
xmxaxrxtxyx
Ok I have a switch for inside lights, navigation lights, bilge and spotlight. Then I have the fishfinders, fuel sender and gauges hooked up like that too. Posting pics promptly
xmxaxrxtxyx
No Title
xmxaxrxtxyx
No Title
xmxaxrxtxyx
No Title
Ice chest drawer
TruckDrivingFool
Where does you trolling motor power come from? Same batteries as lights or is it on it's own battery?
xmxaxrxtxyx
Trolling motor and electric start boat motor are directly hooked up to a separate battery
fishin98
Just finished wiring my Alumacraft...here is a look of the fuse panel the 2 10 gauge black and red come straight off the battery, then everything runs out of the fuse panel, excuse the white wire, using that as a ground wire as I ran out of 14ga black. Then everything runs off the fuse panel, to the switch, aux plug and the depth finder,
xmxaxrxtxyx
Now THATS an organized arrangement!!:)
chasmo
XMAX...I just pulled the wiring harness from under the dash of my 87 Sportsman. There is a buss bar / fuse panel there. The red goes to positive and black to negative of the battery as you know. I have pictures if your interested. I was thinking of putting the same breaker box as above but the original is so simple I'm gonna keep it the same. Trolling motor connects to its own battery thru a 60amp breaker.
