bilge pump wire to the battery
wildemike
Apparently my son disconnected the wire from the bilge pump to the battery, If someone has a 2002 trophy pro model 2052 I would sure appreciate it if you could peek inside the port or starboard battery compartments and tell which side it's connected to before I start ripping things apart under the battery plates.
Thanks Mike
emoney
Re: bilge pump wire to the battery
Trophyboatparts.com has online PDF manuals that include electrical. I'm sure by now you've answered this question, but in case someone is doing a Google search and comes along. Best of luck!
wildemike
Haven't found it yet I had to go out of country for a bit! Looked at the site you recommended didn't show anything talked about a bilge harness I didn't see any such thing on my vessel
Giboni
Did you ever find the location? I am trying to find the inline fuse for the aft bilge to battery
NWFisher
Mike,
I have a year 2000 model 2002. The bilge inline fuse to the float switch connects to the port side battery. When disconnected the wire could drop into the bilge area.
NWFisher
