Big day coming up for the Squall King
Status
Not open for further replies.
ErikDC
I figured I'd start a new thread because the old "Can it get any worse" title seems to be an omen of bad luck and I want to keep it positive and the permanent thread for the refurbishment, I hope y'all don't mind! :D . The first weekend of August we're taking up the deck and removing the transom. I've read nearly every thread and post on the topic here and many other sites and although I learned a TON of good info, I also got a bit confused by the different schools of thought so I'll try and break it down the best I can. 1959 18' Squall King cuddy (says cabin cruiser on the title), wood core glass hull, 1964 Evinrude SportFour 60HP OB. These pictures were taken in the seller's yard, everything has since been removed.<br /><br /> http://i7.photobucket.com/albums/y277/ErikDC/Picture1.jpg <br /><br /> http://i7.photobucket.com/albums/y277/ErikDC/Picture2.jpg <br /><br /> First question: Do we keep the deck? It's not original and was not treated or glassed (except to attatch to hull with very poor glass job) although it's very solid with zero signs of rot. Can we take it up and soak it with resin or should we go for a new deck? Second question: Do we remove the cabin cap to make the transom replacement easier? We have not taken off the rubber rub rail and have no idea what's going on underneath. Third question: Do we need to construct a brace of some sort to prevent the hull from sagging before we remove the transom? Those are the basic three questions I have and although you folks have already helped me immensely, any extra help would be GREATLY appreciated! :D <br /><br />p.s. Sorry about the old pics but hang with me, I'll get newer ones here soon!
Bandslak
Re: Big day coming up for the Squall King
Hi, sorry I really can't answer any of your questions but when I saw this post I just had to reply. Last spring I purchased an old boat and have been trying to find out something about it. I was told it might be something called a Squall King and it was white and blue and also came with a 1964 SportFour 60hp motor. I tore out some old plywood seats and as yet have not decided what exactly I am going to do with it. I had a slight problem with the electric shift in the lower unit but afterwards it ran like a charm. There is some plywood showing on the back of the transom by the water drain hole so I suspect I will have to also replace the transom in the near future. On both sides of the boat, about half way on the top, there are two what appear to be cromed gas caps so there must have been tanks in it at one time. Unfortunately I cannot attach pictures due to lack of a URL.
drewpster
First, Very cool boat! I love the oldies.
If the deck has NO rot at all, why pull it up? You can prep it and glass it in place. Unless of course you suspect water damage to the stringers. Then the answere is yes, you can re-use it. Just be careful how you remove it. If possible make the perimeter cuts at an angle so that it will sit back in place for glassing back in later.
Removing the cap is going to depend on how much access you have to the transom with it in place. If you can get to the transom easy without removing the cap, I see no reason to do so. (but it is unlikley you will have room to work with it in place) Another consideration is how the boat is put together. Remove the rub rail and take a look how it is put together. Getting the upper half off may be easy enough to justify removing it.
If you are removing main memebers, I always recommend supporting the hull the best way possible. It may be as simple is extending the bunks on the trailer or modifying the trailer to support the boat. You want to shore everything to avoid building a sag back in to the hull bottom. You also want to avoid spreading of the hull sides or twist in the fiberglass skin as you glass things back in to place. It really depends on how things move as you remove pieces. On my boat the hull sides spread a good bit when I removed the cap so I was sure to pull them back in as I worked so I could get the cap back on. You can use string lines to check twist and sag as you go.
Bob_VT
This is a post that is over 5 years old and that iboats member has not been here in 5 years.
Bandslak Please, start a new thread of your own. I will let this one sink back into the archives and close it. ;)
Status
