boatdude100
- Jun 29, 2017
- 141
Bad corrosion on outdrive at transom.
It seems my bellows ground wires from ? to ? have been cut or are missing. After 2 hours of searching and viewing schematics, I can not find where they are supposed to go. Please help!
Qs:
1) how much do they matter? (short term and long term) Freshwater Only.
2) I see attachment clips on clamps on each end of the lower bellows. The wires are broken or cut. Do they connect together? Where do they go??
I think the routing is - front of bellows clamp to rear bellows clamp then somewhere on pivot housing AND/OR to "port middle bolt" of trim motor housing
Note: I am replacing trim motor and instructions say "cable for Bellows clamps and pivot housing goes under port middle bolt."(of trim motor housing). So what connects to what? Where does it attach on pivot housing? I assume anyone who has done their bellows knows this. Thanks, please be specific!
Photos are of bellows clamps that have broken wire
Qs:
