Baja H2X....quality & performance???
BlackRocket
Looking at a 1998 Baja H2X...
How's the overall quality?
Are these boats capable of towing a wakeboard? Waterskiier?
How fast is the Fuel Injected 454 at speed & cruise?
Lastly, is 300 hours a lot and when would the engine require rebuilding?
Thanks for all the info!!!
LippCJ7
Re: Baja H2X....quality & performance???
Baja's are great boats for those that like speed and sport, Overall quality is very good but like any boat how the boat has been cared for over the last 13 years is more important. It is easily capable of pulling a wakeboard, skier or tube/towable, but its more focused on the speed/sporty side of boating rather then towing a wakeboard. I have a 454 MPI 310hp(I believe) with a Bravo III and I can do 55 mph that Baja will do better then 60 I'm sure as it is a much faster Hull then my Crownline. 300 Hours on a motor is another relative term depending on the care the motor has received but generally its not middle aged yet In my opinion.
Ayuh,... With proper care, 'n feeding, it should last for 3000hrs...
emilsr
What everyone else said about care/maintenance and the longevity of the 7.4 MPI. If they get reasonable maintenance and aren't run hot they're damn near bulletproof.
Baja is at the low end of the price range for sport boats. You get a lot for your money, but don't expect custom workmanship and rigging. That said, it's the same Mercruiser engine/drive package that the expensive boats use. The H2X is a lot of fun; small enough to pull a skier or wakeboarder, but big enough to run in the chop if you need to. A good friend of ours has a 496magHO powered H2X and it runs 70+mph at wide open throttle. He runs it pretty hard and keeps up with all the big boats until the water starts to get rough. That it's a "sit down" boat (no stand up bolsters) makes it a hard to run in really sloppy water; you can do it, it's just uncomfortable taking the impacts with your back instead of your legs.
If it's been maintained and the price is right I think you'll be very happy with that boat. It's not a purpose built tow boat and it will never be as good for towsports as a Malibu, Tige, Nautique, etc, but a tow boat won't go 60+mph when you want to, nor will they cruise at 45mph and get decent fuel economy like the Baja.
It's a good idea to have a survey and a mechanical inspection done on any used boat, with the purchase contract contingent upon a successful survey/inspection. Especially want to check for rot in the transom and stringers as sometimes the folks at the Baja factory didn't seal the wood very well in places (this isn't just a problem with Bajas). You'll get some additional info from H2X owners at teambajamarine.com.
BlackRocket
Great info all...I like the info that emilsr replied about getting the marine survey done...makes good sense!
