Re: Aluminum v hull restoration, how-to's? Lmuss53's 171CC Sea Nymph Striper
Rivet by rivet and one panel at a time this assembly comes out, each piece supporting another. When that top piece came out and was no longer tieing the gunwales together the sides of this boat got really wobbly. I will have to put that piece back in and get it back to supporting the hull side to side, even if it is a little lower and further forward as the forward edge of the casting deck.
Down to just the pan, it was spot welded and riveted and I had to drill everything out to get it apart. It looks like crap out, I hope I can clean it up to use it again.
Note to prospective tinnie fixer uppers: Drill the rivets all the way out, if you don't they are still hanging on.
Finally it's all out. The vertical pieces are riveted down through the hull and will not come out if I can avoid it.
There was a knee brace in there after all. I think the splash pan will lose about 1/2 of it's length and go back in a lot like it came out, only smaller. Instead of extending the 18 or 20 inches in front of the transom that it was, I picture it at about 8 or 10 inches. The vertical pieces, the old pan, and the supports you can see on the vertical pieces will all be used in the new casting deck.
Little hints that the transom might be wet.
I found something more gross than old wet foam. It is old fuel soaked foam. Sorry no pics but the further I got into it the rottener it got, so I just wanted to get it all out and gone.
Two tools worth their weight in gold on this project. Craftsman 19.2 volt impact driver, and Craftsman 5hp shop vac. I dumped the shop vac today, this far into the project and it was 3/4 full.
I hope to have a helper tomorrow, and I hope to have the transom out and maybe the CC too.
This boat is going to the car wash for a major flushing out when all the stuff is out of it.
