Alpha 1 outdrive stand
Lwarden
Is there a reason I need to build an outdrive stand for my outdrive when I pull it? any reason I cant just lay it on its side?
Don S
Re: Alpha 1 outdrive stand
Won't hurt a thing to lay them down.
Ayuh,... They just take up less floor space stood up,...
Bein' un-vented, you can stand 'em upside-down if ya like....
achris
More fish than mountain goat
Laying on its side just makes it a bit harder to work on... :D;)
Oshkosh1
Ensign
I use a Black & Decker "Workmate" bench. With the prop removed, the whole unit fits nicely.
I've got a second one which I use if I seperate the upper, again, being adjustable it works well to hold/work on.
Lwarden
when I pull my 5.7 ltr engine will it mount up to an engine stand? Id really like to put it on a stand to make it easier to work on. Change plugs/ touch up the paint etc...
Don S
It will bolt to a stand if you remove the flywheel cover, coupler and flywheel.
Lwarden
Thanks Don! thats what I needed to know, appreciate it!
