HT32BSX115
- Dec 8, 2005
- 10,083
Re: Alpha 1 gen 2 / bravo 3 swap
I would seriously dispute this "Propulsion Engineer"s expertise making a statement like this for a difference of only a couple hundred pounds!
That would make the boat nearly uncontrollable if a couple of passengers simply walked to the back of the boat while underway!
Methinks his "calculations" are seriously in error.........
I would absolutely put a set of 5.7L engines in that boat and I wouldn't look back! If you're worried about extra weight, put a set of aluminum manifolds and risers+extensions on it and install closed cooling!
Reasons : 1) I spoke to the propulsion engineer from Regal (30 years on the job) about putting 5.7L in.............................. he said the boat would porpus due to the extra weight in the stern 2) the water would sit dangerously close to the intake due to the extra weight in the stern sitting lower in the water.
Absolutely! AND properly adjusting the drive trim!1. Porpoising can be sorted out with trim tabs (not the useless bits of plastic rubbish on the drive, but proper metal tabs secured to the transom). Or add an extra fuel or water tank up front.
2. Low water line level is solved with exhaust elbow extension kits. They come in 1.5", 3", 6" and 9"... Take your choice. (They are designed for exactly this situation)
Chris.....
YES!And if the boat is that heavy, then the 1.62:1 drives will be PERFECT with 5.7 engines....
