Hello people, nice forum you have here
OK, I'm in the market to buy a new, inexpensive jon boat. The boat will be used strictly for going down the Chicago river. (or Chicago open sewer which we've called it in the past). The "river" is basically totally calm except for the occasional boat wake
I'm thinking of buying a Pelican Scorpio 10.5' or KL Water Tender 9.4', both made from some "new technology" plastic. The reason for plastic is the weight issue, as I intend on hauling it in the back of my pickup truck. I also intend on using a 5 HP motor on the boat, which I already have. The Scorpio can handle up to a 7 HP & the KL a 5 HP
I've read some reviews on these two boats, some good, some bad. The one thing that causes me to hesitate is a few people stated that you can't sit at the back of these boats & use the motor because the back of the boat will sink below the water line
So, my questions are...
Does anyone have experience with these boats or ones similar? How can they make a boat that doesn't allow you to sit at the back & run the motor? Granted, the few that brought up this problem said they weighed around 180 pounds, but so what? I weigh around 220 & now I'm not sure about buying one
Are some jon boat manufacturers really that incompetent? Is this a problem with plastic boats & not metal?
I simply can't believe they could make boats where the person at the back has to be 140 pounds (or whatever) or under
Any advice would be great
Thank you
Thank you
