Advice: 1979 Four Winns "Marquise 170"
wilcahol
I own a 1979 Four Winns Marquise 170 that has a soft spongy floor in front of the engine well. The floor has a covering of 1/8 inch thick fiberglass over what appears to be 3/4 inch plywood. The wood floor has rotted and needs to be replaced. The only way to replace the wood floor is to take out the fiberglass. Is this a project that someone has had experience with?
Hoping that someone out there has experience with this problem and will share their information.
fixb52s
Re: Advice: 1979 Four Winns "Marquise 170"
Search deck and stringer repairs and read, read, read! There is a TON if information here.​
wilcahol
Need a little more direction---is there a special catagory for deck and stringer repair or else go through each thread?
Coors
Spend days, reading them all; different opinions, different methods.
but plenty of pictures.
wilcahol
Thank you. Imagine if one would like to know something bad enough they will spend the time researching it.
