Re: Adding Power Trim
I had suspected that from get-go. Look at the up-side though, you can use one of either size to get your pair. the ones on ebay are obscenely priced, because you can find other full motors with, for the price of one or two rams. That's how I ended up with 2 spares, but one needs rebuilt. In fact I got two full engines (both power heads shot :grumpy
for $350.00.
Kijiji is where I'd be hunting. Trivia: I just learned recently ironically, that it's owned by Ebay.
<Added Note>:
Was reading the PT&T service manual tonight looking for that scan for you. These PT&T systems use low volume high pressure setups. Pump output tests are around 1900 PSI. Do you'll recall in my thread, the hydraulics guys I spoke to about the hoses saying they needed proper fittings, and couldn't repair them using crimp ons with the originals because there wouldn't be enough to hold them in place?
I'm guessing that would be why they said they wouldn't do it.. or IF they did, they would not guaranty them. Keep that in mind should you opt to go that route.
