jigngrub
- Mar 19, 2011
- 8,155
Re: A small bit of advice...Great Foam...!!! ARGH!!!!.....
Have you spoken to the MFGs of pool noodles or blue or pink polystyrene foams to see if recommend using their product as floatation?... and what about empty plastic containers?
Of course the GF MFG won't recommend their product be used for floatation because of the liability and many variables on improper installation.
As I stated earlier in this thread, I wouldn't consider using mass quantities of GF in boat repair/restoration... but I wouldn't have a problem using 1 or 2 cans for a patch or something if I needed to.
I can see that the majority of the members that frequent this particular forum have tunnel vision/blinders on when it comes to this product, but that's ok... it only means there'll be more for me in the store if I should ever need it.
How do you install foam under a deck? Just drill a hole through the decking and pour/squirt it in?... I don't think so.
If you have access to install pourable or canned foam, you have access to paint it.
jigngrub,
I HIGHLY recommend you speak with the MFG of GREAT STUFF foam like I DID and get their opinion about using their foam in the Marine environment for floatation purposes. They do NOT recommend it. I have NOT contacted them about the NEW BLACK aquatic foam but I doubt it is any different. If you want to use it go ahead but this issue has been bantered about here for a LONG time and the consensus is and will continue to be that this product has no place in boat restoration. If you continue to recommend it's usage you will find a LOT of iBoaters strongly disagreeeing with you unless you can get written confirmation from the MFG that they are in agreement with your opinions.
How do you paint foam under the deck of a boat??? Just curious here?
