Re: A question for any scientists out there
You're confusing the pressure exerted on a submerged body by the weight of the water, with displacement.
I'm not the one confused here. Nothing floats perfectly on the surface. Once part of the vessel descends below the plane we call the surface, pressures start to act on it. What ever part of the vessel is below the surface is submerged. As I pointed out, its only about 1/2 psi/foot so the increase is "incredibly minimal". You might not fully understand the mechanism or science, but that doesn't make it so. When you are dealing with a non rigid vessel, you should really look at this as a hybrid system when trying to describe it. Once you do, you can mathematically determine that the increase is indeed "incredibly minimal".
For example, when you submerge a scuba tank the pressure inside does not increase or decrease because there is no change in volume.
Absolute pressure does not change, however relative (usable) pressure does. However, this is NOT a rigid bodied vessel so pressure does affect its volume as well as its buoyancy. If you think that there is very little weight take a tube into a pool and see how deep you can get before the weight of the water on your chest interferes with your ability to breathe. There's a reason snorkels are only 18" long.
When you take Temperature into account Boyle's Law PV=nRT.... or P1V1/T1=P2V2/T2,
You are combining Boyles with Charles' and Gay-Lussac's law. Boyle's Law only deals with volume and pressure, while Charles' Law deals with Volume and temperature and Gay-Lussac's deals with pressure and temperature. Together they form the ideal gas laws and the biggest noob mistake is to not account for absolute pressure and temperature. For temperature add 460 F (273 C) to get to Rankine and for pressure add 14.7 psi (1 bar) for atmospheric.
The water will ALWAYS be cooler than the ambient air temp and the pressure WILL decrease. (Unless you are operating in arctic regions, at which the temp differences will have a negligible effect anyways!)
Or unless you live in Florida. Our springs put out 68-72 degree water all year long. That's why manatees migrate into the springs every winter. Last I checked, we are more sub tropic than arctic.
I have also seen water temps here in the Keys outperform air temps in the winter. The coldest water I have seen down here has been 68 F, and yet I dove when the air temps were a stoopidly cool 42F last year.
The science is not that hard and it clears all the apocryphal BS that people are tossing out like they know better. Like I said, its not rocket science: its submarine science and that's where I tend to play (and instruct).
