99% finished Tri-Hull
Robert D
Pics and video of 'sea trials': http://picasaweb.google.com/rdezsofi/1972ReinellTriHullRestorationAndTest#
Pics of progress and general boating: http://picasaweb.google.com/rdezsofi
Wow. Almost a year of tearing it down and rebuilding. 16 gallons epoxy. Increased the transom to 25" high, and made it 3" thick to accommodate the Force 150 hp motor I picked up for $800 on E-Bay. (Less than 100 hours, runs incredible. Started right up after spending 18 months sitting in my garage!) New deck, carpet, steering, paint, stringers, railing, and two splashwell designs. Ended up making the splashwell functional. I like to toss things in there that the 2 year old can't reach: Tool box, fish net, etc. That meant going with bedliner for the splashwell. And sure enough, while putting the engine cover on for the last final check befor ethe sea trial, I slipped and gouged the bed liner with the engine cover. No big deal, an easy fix with a brush and some bed liner:)
This was an old, ugly, 1972 Reinell with faded gelcoat and a tired Merc 65 hp outboard. The transom was rotted, the stringers were gone, the rotted deck had been covered over by previous owner with new plywood. Was so heavy, wouldn't get up on a plane anymore. The axle weight before I started was 2890 pounds. Today, with all that extra transom thickness and epoxy, new stringers, a motor that's an easy 100 pounds heavier, and with removing the saturated foam, rotted deck and stringers......the axle weight today was 2475 pounds!
The GPS I have says it'll reach 60 mph with a slight tail wind. No wind, smooth water, I think we're talking 56 mph. This thing now flies as fast as I dare go, to the best fishing holes! (Yes, I PASSED a bass boat with a 125 Yamaha during the trials! I left him looking back at his motor wondering whats wrong:))
Lessons learned...and INVALUABLE help from reading iBoats for the past year:
1. Epoxy is the way to go. The strength is worth it. Takes longer to set up, and patience, but I have full confidence in that transom. I also coated the entire inside of the hull with epoxy and some glass for added stregth.
2. I read everything on knee braces. I incorporated 2 knee braces, from the hull to the splashwell, and went 2 inches thick with them. The splashwell itself is almost a half inch thick fiberglass. Reinforcemnet on this boat is probably adequate for 2 outboards in excess of 200 HP. I can't make it flex no matter how I try at any angle. It is solid. You really can improve on factory designs.
3. Wiring. I went with the recommended tinned wire all around. I don't like simple crimp connections, so I did the soldered connections everywhere and used heat shrink tubing on every connection.
4. Paint. This was difficult. Auto painting is easier I decided. After 3 tries at a perfect topside, I was defeated each time by bad conditions. (Left the garage door open a foot for ventilation, and a freak wind gust blew stuff everywhere the first time. Sanded it all down....) After the third time, I decided that this is in fact a fishing boat, and so what if there are 2 runs in the paint? I have a 2 1/2 year old that loves fishing....it will even get scratches, right? The paint is just fine. Not perfect.....but it is a 1972 model!
Bottom paint, I went with an antifouling paint. Dark blue. very happy with that. Went on perfect. I might leave it in the water next summer at the marina.
5. Check the trailer. I read that....and looked. How could I miss anything, but after reading how trailers are neglected, I figured I better give it a full inspection. Damn, sagging springs, missing spring u-bolt, and worn spring bushings! New set of springs was $72, custom made u-bolts all around, $28. Sure pulls nicer now!
6. I can't count how many answers I received from iBoats....it really is a good resource. I have the resources to spend on overkill, and did so for peace of mind. Now that I have tested it out fully, I know this boat will keep on going longer than me. But, I have a toddler to keep in mind. That's why under the deck there is no foam....but on the outboard side of each stringer is a plastic 'bladder' 14 feet long, holding compressed air. (I can add air if ever needed via a port under drivers seat.) Should be enough to keep it floating if ever swamped. Read about foam issues....you will understand:)
7. My wife is SO HAPPY I'm done.....she ha snot been patient:cool: Between that and dealing with a broken elbow, the work went on. To all wives out there: This is an addiction with a huge benefit....please wait till your husband is done to see the results!
Tomorrow morning, Sunday...guess what? Well, during the 'sea trials', everyone we talked to had 'limited out' in trout on Foster Lake, Oregon. People were leaving before noon, because everyone on board had caught their limit. (5 fish per person per day, you can have 2 days limit in possession.) Well, tomorrow...the wife now wants to go fishing! :D
Robert D
Re: 99% finished Tri-Hull
Almost forgot:
Purchased boat for $1700 two years ago. Probably too much.
Spent $2,100 in stuff getting it this far.
Was it worth it? I will say yes........After all, I passed that $25,000 bass boat today like he was sitting still, and I KNOW WHAT MY BOAT IS MADE OF....know what I mean???
Robert D
One more thing: I AM THRILLED with this boat now. I would encourage anyone to just do it. Even if you stretch it out to 2 years. The satisfaction is incredible. And honestly, without iBoats.....I might have made a few mistakes! I will say 30 hours of reading posts. Well worth it. Thank you!
allpoints360
Strong work, Robert! You've got a runner and a stunner, and you've taken something that would have been put through the chipper and made it into something special.
After my first restore, I couldn't help but start another. What about you? Did it get in your blood?
Looks like you got a little angel to help you...
wvmedic
Wow, grate job you have a sharp boat now.
Jeff
jcsercsa
looks great !!! ant it fun out running someone else !!! and yep well worth 2 years it took to do mine !!! John
lakelover
Wow, fantastic! and a great looking boat. Thanks for posting this, I've been getting discouraged with mine with the NY weather & available time not too cooperative. Good to see how long yours took, gives me encouragement!!
Robert D
Thanks, everyone! I have to admit I got discouraged a few times....even took several weeks off without looking at it. Had to recover from elbow surgery in April, as well. Wife got very frustrated also, due to the time I spent on it ;-) So I can't start another one until next spring at the earliest:cool:
jkust
Almost forgot:
Wow a 150 on that...what was the original rating?
drewpster
I often wonder what makes me want to work back breaking hours covered in dust, often waking up with a backache made the night before. Why do I endure setbacks because of inexperience that make me sift through hours of tedious research. What makes a guy like me spend years of labor?
Then I am reminded by friends I have never met. There is a reason. A damn good one!
Outstanding!
Beeched
Wow, great job. It is fantastic to see someone else with the same affliction that I have. You were lucky to have a garage to work in. Mine was all done outside in the elements. Will never trade the experience and satisfaction for anything,,,,,"Priceless". You have one sharp looking boat there. It is worth so much more than any amount of dollars you could sell it for.
Good luck on your next project,,,,,lol
Robert D
__________________
Not entirely sure. The boat was built here in Salem, Oregon under the 'Reinell' name. The current factory is still there, and I do business with them at my work. (Kal Kustom is the name, and they make boats under a couple different names.) I showed them the stringers, and lack of glass...which they said was typical during the early 1970's. Their best guess was that it went out the door rated for up to 90 hp. I had them inspect my transom.....I got a few laughs, as they called it overkill for a 150. Definitely better than factory, even by todays standards.
thrillhouse700
Nice boat, good job on the resto!
Beeched Everytime I see your boat I like it more and more.
Robert D
There is no way I could have done in through the Oregon winter...or spring time, outdoors. I guess I have it easy. Garage is heated with a woodstove, but never gets below 60 degree's due to being in the downstairs of a split-level house. If I had to do it outside, it would take 2 years at least! There is the down side to working indoors: I have a huge mess to clean up! The next sunny day, everything comes out of the garage. Then the leaf blower to blow the dust out. (Have done that a few times!) Then the wife wants everything cleaned one by one. (Camping gear, folding lawn chairs, etc.) Then I have to clean all my tools....the dust got into every drawer in my 3 tool chests. This is a major mess.....but hey, I look at the boat.....and oh ya, it's worth it!:cool:
Robert D
Almost forgot, the wife wanted to get out on the boat today. It was only 58 degree's, overcast with no rain forecast...and we have a 2 year old. I put the top up, we bundled the kid up, she got her Barbie fishing pole and caught a few trout! The wife was very pleased and apologised for being so impatient. She never realized the potential. I think that's what makes us do this stuff: We can look at a boat, and actually visualize what the end product will look like. She experienced for herself, running the 2 miles down the lake in 2 minutes. That used to take us forever and 4 gallons of gas. Now it takes 2 minutes, and very little gas. I saw that little smile on her face when I gave it full throttle.....PRICELESS!!!!! She is now planning the weekends for next spring and summer, as we have many lakes that need to be visited and fished. Our 2 year old says the boat is hers, and she has staked out the front bow seating area...with the canvas cover on it on cold days...as her play area when she's not fishing:D (She took a 2 hour nap there!) Again, I say priceless. If we spent $20,000 plus for a new boat that did the same, it just wouldn't be as fun...because we'd have that monthly payment. This is a paid off boat, and realistically it was done for very cheap, when compared to what a new boat costs. The wife is suggesting names for the boat now.....a very good sign:cool:
Robert D
As I am done.....I now see the time is not relevant. I thought about it today on the lake. If it took 4 years to do it right, it would still be worth it. At 60 mph up on a plane, in what looked like choppy wind driven water, the boat cruised so smooth. A look at the wife....she doesn't like rough water....and I could see the look of astonishment while she nodded approval. Yes, at high speed it was smoother than she ever experienced, and she approved. I also realized that such restoration work is worth more when you have someone to share it with. (OK, are we getting romantic here???) But it's true. This also raised a question for me. A tri-hull at 60 mph, in a 12 inch chop on a large lake, being smooth? I never would have guessed. Then we saw the wake of a passing boat. My wife held on for her life, thinking it would be rough and we'd catch some air. I powered into it at full speed.....and we couldn't even feel it. It was like floating on air. I'm thinking this is enough power that basically the prop and a couple inches of hull is in the water..and thats all at full throttle. This may be what every tri-hull needs....some serious horsepower for rough sea's. Hard corners at speed take some room. It doesn't turn as sharp as a deep-V hull. It slides sideways a bit on the water, but in a very controllable fashion. I've always thought of the Force 150's as equal to maybe a 120hp of one of the major brands.....but for this purpose, it's more than adequate. I did run into the guy with the Yamaha bass boat at the dock, which I passed the day before. I can't believe he was drooling over my boat. He was so upset he had a scratch on his 3 year old bass boat, and worse yet...a 37 year old tri-hull with a Force motor blew by him:p He wanted my opinion on how to beef up his boat for a bigger motor. (I told him to keep it the way it is....more than enough speed to get where he needs to be!) So...if this was 4 years in the back yard....I would love the boat even more. In 3 months, I'll have a 5 or 8 hp kicker motor on board, and it'll be a guys weekend out at the mouth of the Columbia River for serious fishing. (I won't go there without a back up 'kicker motor'......20 minutes with a dead engine, and you're out-to-sea!) Thank you to EVERYONE on iBoats. You wouldn't believe the smallest details that ended up being done after 3 hours of consulting iBoats forums. By the way, there is NO bilge drain as the boat is left in the garage, not in the rain. And guess what? If I reach down there, I find DUST from the fiberglassing:D Completely dry, after 10 hours of boating already. Not even condensation. I'm afraid I spent good money on a bilge pump I'll never need....better safe than sorry!
Robert D
PS: Did I forget to mention it is so awesome, to give a 37 yar old boat full power and actually feel the boat jump up out of the water about a foot and surge forward to an instant plane? :) I'm still smiling, several hours later...priceless!:)
