91 4.3 no water circulation
goodboy
So I got my boat ready for the summer... installed plugs and fired it up on muffs and I'm not getting any water flow exiting the drive.
It's a 91 4.3 mercruiser
You guys have any idea what may have happened?
Where to look first?
I should add its raw water cooled
goodboy
Do we have a write up for doing that?
I can probably Google it...
Any chance its a stuck thermostat?
goodboy
Is the water pump the first place to look?
Thanks for the quick reply
goodboy
Thanks guys...
It's a mr/gen1
Going to order a pump...
Any other thoughts?
I've read some that still had problems after pump replacement...
Ayuh,..... While you've got the lower unit off,....
Back-flush from the in-comin' port at the t-stat housin' hose, to flush out anything in that area, like old impeller bits,.....
If the impeller you take out is missin' pieces, they ALL must be found,....
