Dodgeram67
Thread starter- Joined
- May 21, 2021
- 29
2000 model 90 hp Nissian just got boat water ready and motor runs fine on muffs. Took it out Sunday and on the 20 foot sea ark the motor won't run wide open. Throttle all the way forward and it runs 12 mph. Brought boat home, took carbs off and apart and cleaned them good and ran boat today and same issue. I did notice if I bumped the choke that it would pick up a few rpm and then noticed if I tilted engine way up with prop about to blow out it got to running faster and faster and topped out at 27 mph. Any ideas of issue. I check several other things and they all seemed ok. Plugs good, all cylinders firing. Plenty of gas, diaphram looked good, fuel filter clean, fuel bowl full.
Any help or ideas would be appreciated.
