RCrockett
Thread starter- Joined
- Jul 19, 2012
- 70
I am newbie, but am learning. I hope someone here can give me a direction to go. I am at a loss where to turn at the moment.
I got a 1989 Wellcraft with a 3.7 mercruiser and an Alpha one drive unit. I can hear the groans over my motor already. But, I was told the motor had been gone through but I checked a lot anyway. First outing it would not idle and stalled and left me stranded. Urgh...Water in the fuel...I added seafoam and cracked open the carb to clean it out. Lots of crap in the carb. got it back together and it runs real good. Second outing we cruised down the lake at just above an idle till fluid levels were normal. Went to 3/4 throttle and was running great! after about 5 minutes it started getting loud rapping noise. I slowed down and turned back towards the marina. About half way back the rapping turned to a screeching noise. i slowed down further and prayed to get back to the marina. Nope, everything shut down about a mile away. Had to get towed again.
I know the screeching noise was not good, but cant seem to find out what it was. The next morning i went out and turned the key and it turned over. I pulled the drive unit off thinking maybe a gimble bearing or the U-joints, they looked good. i took the top cover of the drive unit off and all looks good there too. I can put it in gear and rotate the prop and all the gears move fine. With the drive unit off, i hit the key and it wanted to fire up. I am back to thinking it was something in the engine but I am not sure where to start.
I put everything back together and tried to start it up and it wants start but doesn't catch. That is where i left it last night. any help will be appreciated.
Roy
Roy
