88 4.3 omc ignition switch
Brandoninkc
I lost my keys for my boat so I put in a new ignition switch I think I didn't get the wiring correct it will crank but won't start it was acting like it wanted to start a couple of times but the starter wouldn't disengage so I have a yellow wire a purple wire a gray wire and 2 red wires anyone have any idea the correct terminals the grey and purple wire go to? I'm a dummie and didn't take a picture of the original wiring
alldodge
Which key switch did you buy?
How many post are on the switch and what are the labels?
Bt Doctur
usually Red is battery, Purple is IGN, Yellow/red stripe starter solenoid
Lou C
On the switch the terminals are labeled:
B = battery— red wire
I = ignition— purple wire
S = start— yellow/red wire
Some have a 4th terminal that is an accessory position, might be labeled A.
