Re: 86 searay seville Floor down replacement
BIG jump in pictures here, i think the between pics are on our camera,in a box, in a storage unit, someplace......
so here's the floor, as you can see i have a bunch of weight stacked onto the front there, that's to hold it down. You see, the sheet of plywood was nice and flat, until i cut the shape i needed, then it turned into a potato chip, So after alot of spraying with water and weight, I got it good enough to lay it in the boat and get it into position.
PL'ed the edges of the floor to the hull, filled with peanut butter and 1708'ed to the hull.
Glimpse into the front seat bases and how much larger I'm making the storage in them.
some where in there i covered the floor in chop strand and pour foamed the outside of the stringers.
