85 hp evinrude 1972
jesseslighter
I am new to boating and just purchased a 1972 85 hp evinrude I am trying to crank it over the flywheel is turning but I have no spark. As soon as I let off the key I do have spark What could cause this how do I test to see if other components are working properly.. any advise would be greatly appreciated!
RichardNaugle
Re: 85 hp evinrude 1972
low charge to the battery allowing no power or weak power to the coil,maybe run a direct hot wire from the stater solenoid to the coil and see if you can get it to run..i'd be interesting in hearing what happens as i have the same motor
emdsapmgr
Possible you have a defective key/start switch. When the key switch is in the "off" position, it grounds the power pack to prevent spark to the plugs. Disconnect the control box wiring harness under the cowling-that big red plug. This effectively eliminates the control box and key switch from the ignition system. Temporarily disconnect the large red battery cable at the starter. Jump start the starter with battery cables. If you have spark at that point, I'd be looking at for a defective key switch or the control box wiring.
RichardNaugle
after some time and consideration i beleive you have a short in the ignition switch
