aq125a = b21 2.1L
aq131 = b230 2.3L
http://en.wikipedia.org/wiki/Volvo_Redblock_Engine
only thing different externally is the marine circulation pump (water pump for the closed part of the system) and perhaps the distributor.
Manifolds, carb, timing belt, seawater stuff, heat exchanger, should all be the same.
The only way to know for sure is to look up parts yourself for both motors and compare part numbers.
Yes the 131 will mate to a 270.
