'84 Glastron SSV 170 - Won't shift into gear.
tombox
Tried everything and I'm at a bit of a loss. I'm a complete newbie and trying to figure it out as I go along.
OMC Stringer outboard.
I've done the following;
1. Removed the control cable to the throttle assembly
2. Removed the control cable housing at the back of the boat
3. Checked the ball gears for wear (there is very slight wear but nothing serious)
It doesn't matter how hard I crank on the cable pulley the boat will not go into forward or reverse.
At this point I'm out of ideas on what to check next but fairly certain I need to pull of the rear stern drive to have a look. Question is, what am I looking for?
