Also have been collecting materials to modify the trailer. Got a bigger axle and springs (3500#). The new axle is wider than the old one (47 " to center of springs, vs. 64" between spring centers), which should get rid of the "top heavy" feel that it had before. I am also going to get a brake kit for it, as the old one didn't have brakes. Not a problem when I was pulling it with a full sized pickup, but I downsized to a smaller rig, so I think brakes will be needed! I was thinking of getitng a 10" drum hydraulic surge brake kit.
Also got some 4" c channel for new side rails, and some 3" c channel for cross bracing and bunk/roller supports.
Not sure if I will go back with the old rollers (they work fine) or go with some roller bunks. I kinda like the idea of roller bunks, so we will see. Also picked up a few new toys. I have been wanting to get a welder for some time, and the trailer project was a perfect excuse to go shopping. There is a used tool store close to where I live, called Tried and True tools, and if you aren't a new tool only snob, you can score some good deals. Every thing is tested, or else it comes with a three day return. I scored this 220V AC stick welder for $140.
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
. Nothing fancy, but works good.
Been practicing a lot before I dig into the trailer fabrication. I used to be a fair hand with a welder, but I haven't struck an arc in about 17 years or so... so I'm rusty to say the least! Forgot how much fun it is!!
Also found this new in the box cut off saw on CL for $65!
