'82 Aluminum Duracraft Resto
keegan_vann
Hey guys, I'm new to posting things on this website but not new to the reading the forums. I have already semi restored this boat once and am on the resto train again with it.
This time completely revamping the layout of the boat. When I did it the first time I did not have any experience with restoring a boat and didn't do much research while doing it. Consequently, I did some things like wooden decks, spray in bed liner and not fixing rivets that have not been cohesive to how I use the boat. I duck hunt out of this boat primarily but also fish during the spring and summer months as well.
So the wooden decks had already started to rot 2 years into the resto.
The spray in bed liner did not stick well to the wood and added a lot of weight to the boat and I have a leaky rivet boat that has never been fixed and works my automatic bilge pump pretty good.
This being said the pictures I have here are from when I bought the boat, the first resto and what it looks like now that I have started the resto (sorry I don't have a better pic of the first resto). I have stripped the boat down to the hull itself and good thing bc I have found a lot of damage to the structure of the boat. All that leading to my first question, the picture I have last is of what I think are called the stringers? Correct me if I'm wrong, they connect the hull of the boat to the transom. Both are cracked at the interface where they connect to the transom. These I will have to re-weld along with a couple of the cross braces where the welds have also broke.
So my next step after this is to fill the boat up with water and find leaks and replace rivets. Is there anything else anyone would like to add that I should consider before I start to piece the boat back together. The overall layout is to look similar to the last picture here with the exception that there will be a deck on the back of the boat and not just a seat. Thanks for looking and all comments are appreciated.
oops!
Re: '82 Aluminum Duracraft Resto
hi....welcome to iboats
that is one cool looking boat.... !!!!
there are tons of tinnys on this site......look around and you might get some different ideas on what you want for your boat !
Bob_VT
Awesome looking boat! Welcome to iboats!!
I would weld up the cracks and add some extra aluminum to those spots.
Yup bed liner sucks and we here advise against it!!
Here are the aluminum rules.....
Never use PT wood since it reacts with aluminum.....
Use gluvit for sealing the hull seams and rivets.
You must have FUN!!!
keegan_vann
Another question I have is about the foam that I took out of the boat. The foam to the bow of the boat looks fine but at the stern it crumbles pretty easily (shown in pic)and looks fairly water logged. Should I replace this with a certain type of foam? Also what are the disadvantages in not putting the same amount of foam back in the boat during the resto? Previously the rear deck was full of foam (shown in the pic)but I would like to convert that to some storage and put my livewell there. Thoughts?
Woodonglass
Most of the Tin Boat guys use the Blue or Pink Slab foam from Lowes. Remember it does NOT help the boat float better, it only aids in case the boat swamps and begins or attempts to sink. Enough foam will keep it off the bottom.
jigngrub
I would suggest that if you take foam out of a specific area you should put the same amount or more back in the same general area. Foam is an underrated safety feature.
keegan_vann
Perfect, that's exactly what I needed to hear. Will be working on leaky rivets tomorrow!
all duck'd up
any updates?
also i have a question about your 5th pic in your first post. why do they have a stearing wheel on a gatortail motor?
ive only seen tiler handel ones and figured that wouldnt do to well with logs and mud
