81 Evinrude 25 HP - No fuel to bottom cylinder
willy007
Re: 81 Evinrude 25 HP - No fuel to bottom cylinder
Well, when you go through and clean & rebuild your carbs you'll most likely see the issue if there is one there (either a clogged jet, passage way, dirt, or debris). If you take apart the carb and everything is clear and clean than you may have to look deeper. It's hard to eliminate possible causes without really checking them. When you do get around to rebuilding them make sure to test/check the float & make sure that the needle seats properly.
cchildr84
Ok that sounds good. So I got the block broken apart and pistons removed last night. See photos below. I'm not sure how tight the rings are supposed to be around the pistons when not in the cylinder, but they were pretty loose and could easily be removed without using ring pliers. With the exception of the one on the bottom cylinder which was stuck due to all of the debris. What do you guys think. The first two pics are of the upper piston, the next three are of the bottom piston.
Chinewalker
Rings are supposed to sit loosely in the grooves, with upper ring sitting even looser as it is a keystone style ring. Bottom piston is absolutely roached! If the bore it came out of isn't too badly scored, you may get by with a new (or good used) piston and fresh rings.
AlTn
any chatter marks or "bearing shadows" < don't know the proper term > on the crankshaft?
cchildr84
Bottom piston is absolutely roached! If the bore it came out of isn't too badly scored, you may get by with a new (or good used) piston and fresh rings.[/QUOTE]
Yeah, as bad as that piston looks like, the cylinder it came out of doesn't look that bad. And the funny thing is, is that all of that damage was on the intake side, and the scoring that occured in that cylinder; picture in previous post, is on the exhaust side. Any thoughts as to what could have caused that damage, or what chain of events could have taken place to allow that to happen?
cchildr84
I'd have to double check, but I believe there is. How bad is that if there is. I'll try to post a pic tomorrow.
AlTn
told by a reputable machine shop here," Yes, we can grind them out then polish the crank but, who makes oversized bearings for it?". I recently went through this with an 1971 18 hp. I located another crank for $65 and had it polished. If the crank has these marks, then the bearings on that rod likely need replacing too.
cchildr84
Alright, here are some photos of the crank. I didn't think it was to bad, what do y'all think. I was going to replace all the crank bearings and seals, and rod bearings regardless of what shape they were in.
Chinewalker
Hard to tell for sure due to glare in photos, but that crank looks alright to me. Chatter marks or rust ridges would be pretty apparent.
cchildr84
I suppose I'm still not sure what a chatter mark is, but to the touch there are no abrassions or apparent ridges. Now on my to do list, is to find a reputable marine machine shop in the College Station area.
AlTn
I'd suggest to you to call the marine dealerships in your area for referrals to the machine shops they use
cchildr84
Alright, the block is in the machine shop, and they said .020 over would clean it up. So I look forward to getting it back so I can get the ball rolling with this rebuild. Next thing is to order all new bearing and seals and the shop manual. I didn't want to spend another dime until I new the block could be machined.
AlTn
have you sourced some .020 over pistons and rings?
cchildr84
The machine shop the block is at, is also a WISECO supplier/dealer so I'm ordering the kits through them. However, its the same kit you can get through marineengine.com and the like. Part #3127P2.
cchildr84
Just thought I'd give an update. The block is still in the machine shop awaiting the arrival of the new pistons. In the interim I've received my shop manual from Ken Cook. It's pretty in depth, although some of the pictures aren't very ledgeable as they are in black and white. I think I'll go ahead and re-build the carb while I'm waiting Looking in the manual, it appears that the breakin time is only a 5 hour break in as opposed to 10 hour which I have read in many articles on line. Any thoughts on breakin?
cchildr84
Looking in the manual, it appears that the breakin time is only a 5 hour break in as opposed to 10 hour which I have read in many articles on line. Any thoughts on breakin?[/QUOTE]
Any thoughts guys?
nwcove
assuming that the machine shop will be doing the assembly? if so, i would follow their recommendations to a tee!!! jmo
cchildr84
No, they're just doing the machining. I'll be doing the re-assembly. I suppose I'll ask there recommendation though. Perhaps, since the piston set I'm getting is from WISECO, they would have some recommendations as well.
likitvi
Just a note worth remembering: Remember to pay attention to the position of the rings when installing pistons. I would assume this is well covered in the manual.
cchildr84
Yeah, this part is pretty detailed. The top one is a keystone/beveled type ring and the bottom one is not. The ring grooves have a pin that the end gap aligns with. This is my understanding of the manual, please correct me if I'm wrong.
