Woodonglass
- Dec 29, 2009
- 25,924
Re: 81 Checkmate Restoration!
Nope, TCP Global online does.
[FONT=Verdana, Arial, Helvetica, sans-serif]
Brand Spray Gun Nozzle Sets
for G6600 Series HVLP Spray Guns
(Needle, Nozzle and Air Cap Only)[/FONT]
Stainless Steel Spray Atomizing Sets that fit all TCPglobal Brand G6600 Series HVLP Spray Guns
(The 2 Full Size Spray Guns in our TCP G7000 3 Spray Gun Kit are G6600 Series Guns)
Common TCPglobal Brand G6600 Series HVLP Spray Gun Nozzle Size Applications:
(Click on the Nozzle Size to Purchase)
• The 1.3mm Fluid Tip is Ideal for the Optimal Atomization of Basecoats, Clearcoats and other Light to Medium Viscosity Materials.
• The 1.4mm Fluid Tip is Ideal for the Optimal Atomization of Basecoats, Clearcoats and other Light to Medium Viscosity Materials.
• The 1.5mm Fluid Tip works for Topcoats, Basecoats, Clearcoats, Sealers, Primers and other Light to Medium Viscosity Materials.
• The 1.8mm and 2.0mm Fluid Tips are excellent for Single and 2K Primers, Oil Base, Latex, and other Medium to Heavy Viscosity Coatings.
• The 2.5mm Fluid Tip will enable you to spray thicker materials such as [FONT=Verdana, Arial, Helvetica, sans-serif]Extreme High Build or Polyester Primers, Thick Enamels, Latex Paints, Chip
[FONT=Verdana, Arial, Helvetica, sans-serif]Guard, Metal Flakes, Gel Coats, Etc...[/FONT][/FONT]
