massimofinance
Thread starter- Joined
- Oct 30, 2004
- 508
A good friend gave me his eighties bayliner. Apart from the engine work, I would like to do some "sprucing up" and would like your opinion:<br /><br />1) The floor is plywood, with a cut out piece so you can reach the bilge pump. I would like to perhaps cover it all with fiberglass or some rubber coating material. (looks to be in good shape) any suggestions?<br /><br />2) There are a number of pieces of plywood covered with carpeting lining the sides of the boat, inside, in the cockpit. I would like to remove these, perhaps replace them with same size and dimension plastics, is this a good idea?<br /><br />3) The seats are cracked, is there a good, cheap way to fix them?<br /><br />4) The blue canvas cover has a number of the snaps: rusted and broken, is there a way to fix those?<br /><br />5) I would also like to remove all the carpeting, and replace with something more "marine" and durable, suggestions?<br /><br />Thanks, I am looking to do this on a shoestring budget, so any suggestions are appreciated.
