'79 Starcraft SS 16 restoration
Status
Not open for further replies.
lakelover
Re: '79 Starcraft SS 16 restoration
I'd definitely start it at home before dragging it to the water. Mine started, but I ended up having to replace the OMS pump for it to stay running over an idle. Nice job on the steering, I don't think you'll have any problem. Do you have rack or rotary? Everything looks great, excellent work. I guess instead of saying perfect match on the seats, I meant that the two colors go very well together. Hope you can report back after some time to say how the vinyl paint holds up. What's your ETS (Estimate Time to Splash)?
Triton II
Hey HA,
Looking good mate, but may I suggest a slightly longer bolt on the steering arm at the engine bracket so the thread goes into the green locking part of the nyloc nut. From the photo it looks to be an 1/8" or so too short?
TII
Huron Angler
Kill circuit is usually black with yellow stripe.....this is for the later style remote but it may help some.....
http://maxrules.com/graphics/omc/wiring/REMCONTBOX.jpg
Thanks Mark, that is a great schematic for reference.:)
Thanks LL, the steering is rack. I kept the one that came with the boat, will probably replace it at some point and get a stainless wheel.:D
We had the boat out last friday evening for a test run with the 70hp, I have some more info to post on that:)
Hey HA,
TII
Wow you noticed that huh? Good eye TII.:)
I was able to take it apart again and removed one washer, so the bolt is through the nyloc a bit.
GA_Boater
We had the boat out last friday evening for a test run with the 70hp, I have some more info to post on that:)/QUOTE]
Did you do a stealth splash to avoid the Mod, HA? How did it go? Got:D?
Huron Angler
We got the new registration stickers on the boat last week.:)
The 3 is a little crooked, the admiral wants to redo a couple.
This is the piece that was removed from the motor so that the steering arm I bought on ebay would work.
A look at the helm dash panel prior to installation.
This is the wiring for the CMC bracket relays. I will need to get the relays in a good dry location.
Huron Angler
We got the port windshield bolted in place.
I am planning on buying a nice dry glove box to install so I'm holding off on installing the dash panel just yet.
Here's a shot of the controls partially assembled and bolted onto the side panel.
I took it apart to insert new stainless bolts, since the old ones were rusted out pretty well..
Fully assembled controls.:)
Huron Angler
We had some help getting the windshield cleaned up.:)
Motor cables got routed through the boot and attached to the motor.
dozerII
Looking real good HA, nice to have a great helper crew like you have there. Won't be long and you should be cruising around the lake.
Glen
Huron Angler
So here's the report from the first lake test of the motor.:)
Last friday night my buddy called up wondering if crappie fishing was on the agenda.
I told him that all that was left was to quickly install the steering wheel and rack to the dash.
I got busy on that and of course installed it backwards again.:facepalm:
Give me a 50/50 chance I'll screw it up every time. This is why I do not gamble.:D
We loaded up the kids and headed out to the lake, my fishing buddy and his wife along too since we planned on fishing after testing out the 70hp.
Long story short, the beast fired on the second turn of the key, no choke needed.
I realize instantly that she is idling WAY too high and I do not even have the warm up lever raised.
I let it rev for a few seconds and it occurs to me that the motor is potentially bothering the 4-5 other boats on the tiny lake. For this reason I shut her down and we proceeded to troll for some crappie with the Minn Kota.
The warm up lever is full on basically, so I will be adjusting the throttle cable a bit and hopefully get things worked out.
So it seems that she wants to run and we are hoping to get back on the water soon.
Lots of family stuff going on lately so we have been out of town a lot.
Here's another shot of the registration stickers on the bow.
One of our trips out of town was to visit Roslynn's grandparents.
We thought it would be a good idea to bring the SS along to let him check out what we've down with her. He has restored plenty of cars, campers and boats himself so he appreciates a good project.
It's about an hour and fifteen minute drive and about halfway I stopped at a rest area. Having noticed a weird shimmy in the trailer I was a bit concerned.
I looked at the port side bearing first, inspected it and tapped it with my finger to see how warm. Not hot, just warm and I stepped over the bow and checked the starboard side.
Not using good judgement I went ahead and pressed my index finger on the bearing and it sizzled like bacon. Ouch:facepalm:
So long story short, we made it on side roads the rest of the way. Stopping every so often to let it cool down, knowing that the bearing was already shot we just wanted to get to a place to work on it.
So here's the new hub and bearing installed. For $60 at Tractor Supply, who remarkably was open on the 4th of July.
Rather than wonder if the replacement bearing would fit properly, we just got a new hub as well.
To cap things off, my Explorer now has a short in the running lights and I have no way to safely tow the boat or drive at night. Hopefully it's a failed switch and not too much $$ to fix.
Huron Angler
After checking out the boat, Roslynn's grandpa decided that we could have an unused bimini top that he had laying up in a loft over his workshop.
I think it's stainless, and in great shape. What a surprise and a great gift!
The canvas has a tear, but if we use this as a template we can probably replace it with white of grey material.
It is way too wide for the SS, so it will either get chopped down or be saved for use on a Starcraft Islander project.
I might even measure and see it it's the right width for a 22'.
Here's the helm installed.
I will be taking this apart again later today to flip the column and correct the backwards steering.:redface:
dozerII
HA, seems no one in the Starmada is able to escape Murphy. Good score on the Btop. I now carry spare hub with pre packed bearings after the trip to Minnesota.
BonairII
Don't feel bad......I mounted the steering rack backward on both steering installations I've done in the last year. :facepalm:
Huron Angler
That's a good idea Glen. No fun getting stuck halfway home.
Thanks, I knew I wasn't the only one:D:D
So I did manage to get the steering disassembled...and then reassembled properly.:)
We also worked on getting the plywood pieces attached to the front of the consoles. They've been sitting in place for a week or two.
Nice to get things bolted down permanently.:)
I'm going to get started on installing the GPS and fishfinder today when we aren't troubleshooting the throttle cable.
Also on the list is bolting on three Berkely rod holder bases up in the bow.
Running planer boards requires many rod holders all over the boat to spread everything out properly. I also have one Penn manual downrigger but we are gonna hold off on mounting that for now.
I'm nowhere near being 100% done with the boat, but we are probably going to be using it as we finish for the rest of the summer.:)
jasoutside
That's cool man, she ready!:)
I do hope I can join you soon:D
Bwana Don
Hey HA, it's been a while since I popped in looking good. I see as the kids get older they are put in charge of more phases of the resto. Have they been trained to use a paint sprayer yet? Maybe Santa will bring them respirators, hint. Maybe an air compressor too. lol
Huron Angler
It would be nice to be able to cruise around to cool down with all this hot weather.:D
With the short in my vehicle we cannot take the boat out right now. I'm hoping to get it fixed by this weekend.:)
Thanks Don:)
We recently purchased properly sized leather work gloves for the boys, since they love to help stack wood and help clear our quad trails up north.
They want their own ear protection too, since we are running the Stihl quite a bit and the adult ones don't fit well.:)
Huron Angler
Hey HA.. I was just going to tell you I have a stainless steering wheel I'd seel you cheap, then saw this one on eBay and thought yuou might be interested.
http://www.ebay.com/itm/Vintage-Nau..._Accessories_Gear&hash=item2ec024f88c&vxp=mtr
It's a 6 spoke for $23 shipping included...
You boat is look great man!! Don't you just love that shark Nautolex??
Thanks Tom:) I would love to upgrade to a nice stainless wheel like that one:D
Unfortunately I will need to spend some money on a new tow vehicle apparently.:(
The Explorer has a short in the wiring such that the running lights didn't work.
Then the lights stayed on all the time, now the fuel pump went since I pulled a fuse rather than unhook the main leads to avoid draining the battery.:facepalm:
Not sure if I'm gonna be buying something new or spending money on repairs.???
Huron Angler
I got two rod holders mounted, one on each side. These will be great for running planer boards to spread lines out when trolling.:D
Status
