'79Evinrude200
Thread starter- Joined
- Sep 15, 2009
- 3
I have a 1979 Evinrude 200HP with the original controls; everything has been running tip-top as usual; however, I've done a bit of striper trolling this season (as usual) and all of a sudden between one neutral and forward shift the throttle portion became extremely difficult to move. I was still able to continue fishing and using some pressure later got it up on plane and back to the dock, no problems.
Just wondering if this is a lubrication issue inside the control box?
Again. It is shifting fine: neutral, forward, neutral, reverse. It is just when trying to put the throttle down it requires more force than should be required.
Thank you for any help.
