78 OMC stern drive wont lift
7946376
Can anyone help? When I hit the tilt switch I hear the elect motor turn but it wont lift the drive. It's like somthing is slipping:confused:[/SIZE]
NW Redneck
Re: 78 OMC stern drive wont lift
Follow the steps in the post chiefalen linked and that should either get you going or eliminate 90% of the system as the problem. If still no joy, do a search on 'OMC tilt' and there's a few good threads on this topic. Check back here if you have any specific questions. There's a good chance that your tilt motor will need to be cleaned up or rebuilt too. They are prone to moisture and corrosion, especially if the bilge has ever been flooded. :eek: It just takes forgetting the plug ONCE. :D
